Root I'm having problems with Titanium Backup
mudking
Today, I installed Titanium Backup and I've had some problems. First, it couldn't get root access. I know I have root, so I pushed "problems" and installed busybox from there. It worked after that for awhile. Then, I just try to go into Titanium to do a backup and it's telling me to turn on debugging mode and allow unknown sources. I already have both debugging mode and allow unknown sources ticked on. So, I went back to settings and ticked them both off then on again. I go back to Titanium and it works fine, but only once or twice. Then, it gives me the same warnings again. I remember reading something about installing busybox from Titanium causing problems, but I don't know where that was or if it applies here.
Long time Ti user. Never had a problem once it was setup. Have you rebooted since installing busybox?
I can't remember now if I had rebooted right after. I certainly have now and I haven't seen it again yet. So, it's ok to be using the busybox that Titanium installs? I don't have to install a modified busybox for the TB?
I didn't have to. I installed Busybox through Ti and then a few other things and rebooted. It's worked fine ever since then.
Maybe you hit the nail on the head then. Maybe I hadn't done a reboot after installing busybox. I haven't had the problem again, so that would make sense. Thanks, I hope that is all it was.
