over88mph
Member
I backed up with Titanium Backup.
Now the sync icon will not disappear from the tray.
That is irrelevant and minor.
I could not get ROM Manager to reboot to the screen that gave the option for 'install zip from sdcard'
It would only go the screen that said 'reinstall packages' and 3 other options.
This happened in manual mode and reboot from ROM Manager.
How do I get the 'install zip' option ?
Should I have just used the 'install from zip' option within ROM Manager ?
Before I thought of trying that...
I deleted my update.zip file. Stupidly.
I downloaded one from a fourm post, so I can get thru the recovery reboot again, but my OCLF program is not running properly.
This seems to have affected all apps that need Superuser access. Including ROM Manager, so I cannot try using the option within ROM Manager.
It's as if I an unrooted, but not able to reroot with OCLF. Apps give a superuser error and force close. OCLF, Root Explorer, Superuser permissions, ROM Manager all shut down.
Did I royally screw up ? Will ODIN flash to stock get me that file back or get stuff working again? Is that too extreme ?
Any help appreciated.
