I want to go back to completely factory and clear any trace of root. I'm not a developer, have no clue what I'm doing, and don't have a way to fix anything if something happens. Also little use for root really. I've rooted my LG Volt twice now. The first time was a little more scary because while towelroot went fine, SuperSU was a different story. I read to get rid of it, you just go to the option about switching to superuser. That did nothing then I just did uninstall root, but wasn't sure if it got rid of all evidence so I factory reset it?
I know soft reset is just restarting the phone I think, hard reset is from within the phone while it's powered on, but going to the reset option, and factory reset has to be the Vol-, power button together while the phone is off. If I'm wrong please correct me.
With this root all I installed was BusyBox and actually only rooted it because even after the reset I was noticing options not being saved in the menu upon reboot or they would only be half saved so I thought maybe there is an issue with permissions and I need to root again. I've used Ubuntu and kind of have an idea of how easy Linux is to screw up so I could only imagine on handheld device that is mostly controlled by the vendor you bought from what could happen.
The first time I wasn't sure to uninstall BusyBox before SuperSU first or not, if it made a difference at all. I know removing SuperSU was the end of root so I saved that for last. Anyway, my phone only has BusyBox on it at the moment and that's because I thought it was necessary with rooted phones, I don't know.
Is there a way to remove root without resetting it and will there be a single trace of root/rooted apps if I completely reset the device? I don't have insurance on the phone so rather be on the safe side and just use the device as is. I respect the work that's been put into rooting and all that comes with it, but I spent $160 including the tax and don't use my phone for much besides text, call, weather, pictures, web, simple things.
One more question. My LG Volt is running 4.4.2, but the latest is 4.4.4 so will it ever be updated? Does LG update all their phone's software at once? Am I not getting the update because I'm rooted?
