Should I go into a Verizon store and see if they can turn it on? I mean, if they can't turn the phone on, would they really know I rooted it? :S =[
Well I have 4 different roms, the root file, and a custom lockscreen file.
the "root PB00IMG.ZIP" file can not be flashed to the phone using Amon_RA's recovery. BTW, you should probably rename it to something slightly different, say "root-PB00IMG.ZIP" so that if your phone happens to get started up in HBOOT mode, your phone won't try and start the rooting process over again
