Root I'm rooted!
AndroidJane
Don't be afraid, it was quite easy to do! I'm downloading Tibu now - hopefully I don't muck it up from here! Thanks all for your help!
Thanks! I'm excited! I do have another question...should it take 30 minutes to download Titanium Pro? I'd say it would depend on my phone/signal...right?
You were correct, everything depends on your signal strength. I notice a big speed difference between having 2 bars or having 3 bars. However, I try to do all the downloading over WiFi instead, as it is so much faster.
Droid boot sound? Awesome, I keep meaning to get to doing that myself!
Yes! I was dying to get rid of that Hello hello hello thing..... I'm trying now to change my boot animation using Boot Animations Installer but no go...says I need Nand Unlock? Can you or anyone suggest another good app to do this?
