Root I'm stock :(
ImageJPEG
Member
I had to use the RSD Lite to get my phone to stock :(
I upgraded to the .901 update without knowing you can't root it yet. I've tried going back to .893 but I get an error with cdt.bin. (thank God for the .901 cdt.bin fix)
Does anyone here know anything about reverting or rooting .901?
Ok, so I get the phone in Fastboot. I then run the cdt.bin fix and reboot back into Fastboot then run RSD Lite to get back .893 stock rom. Still fails at step 6.
I've tried starting RSD Lite first then rebooting when it fails and run the fix, then try try running RSD Lite again and still no luck.
Do I run the .901 cdt.bin fix before or after I flash back to .893 with RSD Lite?
I stupidly "upgraded" to .901 and I'm trying to get to .893 to root it, then upgrade to .901.
After. You run the flash first that replaces everything with the old 5.5.893 stuff, and then it gives youa boot error, whereupon you go back and flash the cdt.bin - and then it boots normally into 5.5.893.
Then root, 43v3r r00t, then apply 901 again.
Also, note:
I Highly Recommend that you reboot between each step so that you can verify what is actually happening, except between rooting and 43v3r rooting, that is really not necessary.
I put my phone in Fastboot. I ran the RSD Lite program with the .893 Rom. I then shut off the phone and turned it back on. Fastboot came up with an error. I then started the cdt.bin fix. I'm now looking at the System version and it shows 5.9.901.XT875.Verizon.en.US.
Still .901 :/
I am trying to find the link now but I believe when you flash the 5.5.893 fxz file it will say flash failure cdt.bin something or other. You are then going to have to push the .901 cdt.bin file and boot up. As soon as I find the link I will post it.\
here is a thread with the files you need to get .901 with root.thread
this puts you in the middle of the thread, scroll down till you see post #39 and start from there. Also read the op before you do anything.
That's why I said reboot - as dfib and I both said, after flashing .893 you'll get a boot error - the phone will not boot. If you reboot between these steps you can verify it is actually doing like it is expected to.
My guess is that 893 is not actually being flashed to your phone....
*facepalm*
I did get .893 installed and rooted. Then I was able to upgrade to .901.
I installed the Liberty 2.0 Rom with the .901 patch. Well it turns out that it was downgraded to 5.5.886.XT875.Verizon.en.US
Start all over. Only this time skip Liberty.
It's frustrating, I know - but it's worth it in the end....
