Help I'm stuck in Fastboot. Please help?
Crex321
Alright, so I heard that ClockworkMod worked for Lg Optimus M, so i tried it out. I think I followed the instructions correctly, but i didnt see any results with the ClockworkMod saying its working.
So, after that. I wanted to see if recovery mode changed at all (I have joneidys recovery installed), and i went into recovery mode. Now, all my phone says is:
Fastboot mode started
udc_start()
-- suspended --
-- suspended --
-- reset --
-- portchange --
-- reset--
-- portchange --
What should i do? Please help me. Thanks.
I saw that. So far i've done everything correctly, but when i'm trying to open a file from lg united mobile drivers called lgandadb my computer tells me "your attempting to open a file of type of 'system file' (.sys)" and that i have to chose a program to open it with.. i tried all of the ones i have and neither of them can open it, or let me select it to move onto the other steps.. what should i do?
i have the same problem except that i downloaded rom manager nd i need to know the easiest way to get out of fastboot mode
Can someone help please
Thanks,
Thanks,
http://androidforums.com/optimus-m-all-things-root/382525-guide-get-out-fastboot-mode.html
Go there. EVERYTHING worked, and my phone is saved. I was trying to do this on my Windows Xp, and nothing was happening in Command Prompt. But when I used a friends computer which was a Windows Vista, it worked like a charm... I guess that means, I need a better laptop.
