Help im stuck maybe you can help?! :)
danibug23
well i have the incredible 2 right now and love the phone but i just want a bigger screen. i was thinking about the razr then i start reading reveiws and im like ehhhhh maybe not then i found the rezound. has anybody ever switched from the incredible 2 to the rezound and loved it? or do you hate it? is this phone better than the razr? maybe you guys can help me out. OH one more thing i want a bigger screen how big is the screen on the rezound and how about the battery life? thankk you guys for taking time to post to me. :)
screen is 4.3 and is absolutely amazing.
battery life varies on A LOT of things. Personally for me and others 10 - 15 hours of moderate use was pretty easy to get. That is turning off 4G when not needed and also using WiFi when possible.
FWIW, My phone has exceeded all expectations. The screen is beautiful, the battery life is very good especially if you set performance on "normal", the form factor is perfect for me, the phone is fast, the interface is great, huge amount of customization, etc.
As to battery life here is a real life experience from yesterday: My phone ended the day at 40% after 2 hrs of talking on three calls, 33 minutes of internet, 76 min of music listening last night, three gmail checks, and 14 text messages. It was on for 23hrs 17min since previous charge. Standard battery.
I highly recommend this phone!
For me the Razr was too thin and felt too flimsy. The screen was not as good to my eyes.
I suggest that you go to the store and try the Rezound seems that in person it actually sells itself.
I came from the Incredible, also wanted a bigger screen. Looked at the razr and didnt like it, as said felt very flimsy and did not fit my hand well. The rezound is excellent, no problems, battery is pretty decent, and the screen is AMAZING!!
While the screen is only 0.3 inches bigger, it actually seems even bigger than that because the aspect ratio is different. The inc2 uses 800x480 or an AR of 1.67 while the rezound is 1280x720 or 1.78. Since both screens use the same SLCD tech just try to image an inc2 screen with a noticeably taller screen and 1.5 times more clarity.
Or better yet go here and click toggle screen:
Phone Size - Phone size comparison made easy!
Ya I've had the incredible 1 & 2 and the rezound (I'm not meaning to get all htc phones I actually was going to get the nexus) its a way big improvement over the Inc2 its a lot less buggy and a lot faster and the screen is amazing i
I had both incredibles and now the rezound and I couldn't be happier. It's just all around better IMO
