cthomas2009
So i have tried multiple Instant Root applications for my Tablet, like z4root, Universal Androot, etc. None of them will permanently root my Tablet. It will Temporary Root it, but if i click on full root, it will root and then reboot. After it reboots, it is no longer rooted and Superuser Permissions no longer work unless if I do another Temp Root. Ive listed the full specs on my Tablet below. I dont know the manufacturer of the Tablet because I bought it from http://www.lightinthebox.com/ which is a china wholesale retail. This is the link to the device I have http://www.lightinthebox.com/Android2-1-Tablet-MID-7--TFT-Touch-Screen-Track-Ball-ARM-11-RK2818-600MHZ-DDR2-256MB-2G-Wifi-Gsensor-M98A1137PC06-_p162529.html
Its like after it roots and reboots, it seems Superuser and root privileges dont stick, they just get erased. And if I do a Temp Root using Universal Androot and use the Root Explorer app it will not let me mount the system as Read/Write, it only sticks to Read/Only so i cant delete any stock apps on the Tablet. And if I Temp Root, and go to Rom Manager and try to install a new ROM, it will boot into recovery, but i cant scroll to select any of the different options within Recovery Mode. Please help me! Can i permanently root my tablet somehow someway?!? Heres the specs:
* Android ID: 20014381c430d0f8
* Android version: 1.0.0
* Release Codename: REL
* API LEVEL: 7
* CPU ABI: armeabi
* Manufacturer: unknown
* Board: trout
* Brand: rockchip
* Device: sdkDemo
* Display: V0.18.ECLAIR.eng.root.20101215.174354
* Fingerprint: rockchip/sdkDemo/sdkDemo/trout:2.1-update1/ECLAIR/eng.root.20101215.174354:user/test-keys
* Host: ubuntu
* ID: ECLAIR
* Model: Android-for-Rockchip-2818
* Product: sdkDemo
* Tags: test-keys
* Type: user
* User: root
Other specs say "Hardware: RK28board" and "Processor: ARM926EJ-S rev 5 (v5I)
PLEASE HELP ME! Itd be much appreciated
* API LEVEL: 7
* CPU ABI: armeabi
* Board: trout
* Brand: rockchip
* Device: sdkDemo
* Host: ubuntu
* ID: ECLAIR
* Product: sdkDemo
* Tags: test-keys
* Type: user
* User: root
