Help IMEI deleted
sps
Dear,
I have a Google Nexus 4, have been using my phone from last 6-7 months, last night I woke up and I see no network on my phone. I did hard reset on the phone and wasn't helpful, then I saw there's no IMEI entry on my device.
I wrote to google and they said we can't help send device back to LG. Problem is I bought this device from grey market without bill.
does any one know how to get IMEI number back on to the device.
Attached are few pics.
PLEASE HELPPPP MEEE !!
Unless you have a backup of your efs data, there really isn't a way to fix this. Best bet would be to flash the factory image and hope that fixes it, though I think the odds are low. If that doesn't do it, only LG can fix it.
how do I know if I have backup efs data? and how do I flash the factory image?
Backing up efs is a very technical procedure that requires usage of the Android development bridge. Chances are you'd remember making a backup due to how difficult it is.
As for flashing a factory image, that would require unlocking your bootloader and completely wiping your device. If you have a windows pc, it can be fairly automated through the use of toolkits. However, due to the relatively low chance of success, is still recommend attempting a rma with LG.
