Root Imos 3.5.8
Tboltfan25
I was wondering if anyone can link the kernel for me, and maybe give me a brief one description of how to properly install this kernel. I'm runnig uberbamf pr3 and I'm interesting in trying this kernel out
3.5.11 is the least aosp kernel. It has a noticeable audio tweak but seems to kill my battery quicker.
so to overclock on this kernel, you have to use terminal correct? and the only options you have are 1.41 and 1.92? I remember using a ROM with the overclock/undervolt settings baked in, and I was able to pick a wider variety...i.e. 1.2,1.3,1.4,1.5..etc. I was wondering if there is anything available that allows that type of tweaking with this kernel...I'm downloading this now :) first kernel change, im excited!
If it has support for the speedtweak.sh script then you could over clock in terminal. If your rom has built in OC features then you can use that as well. If it doesn't but you don't want to use it then you can use setCPU (get it at XDA for free or on the market to support the dev) and set it to any of the slots built into the kernel.
Just flashed it, all the options showed up under Bamf settings...running butter smooth. Im hoping to see some battery life improvement after switching to this kernel.
