Help Impossible to delete browsing history on Epic??
Adlebo
It doesn't seem that you can totally delete browsing history on the Epic. On the browser I pressed Menu, More, and deleted all browsing history, data, cache etc. So when I checked in history there wasn't any websites listed. BUT when in the browser you click on the back button, you still can get to the previously seen sites. So how can you totally delete your browsing history??
Before you clear, go back to your home screen. Close the browser, clear and see if that works for you.
One thing that I have found very helpful is after I clear all of the histories....When you go back into your browser select the settings soft key and then select the windows soft key. Once here you can clear any window that seems to not want to go away. Once I started doing this the back key will only kick you back out to the main display.
