NeoGrandizer
Android Expert
Well, I did some screen shots after some constant use to see how the battery holds up. With Opera, I was mostly using data connection (4G non-LTE) and some WiFi.
When I'm out I force hspa+. Either way I have a serious drain while using the note. The picture above was overnight. I don't know how in the world that battery drain happen like that. Very very frustrating and I guess I will have to invest in a pregnant phone or have them send be out another battery. Thing is I live this device so unlike my others where as I just got another device I can't go back to a smaller screen size LBVFS"
...Just installed Easy Battery along with the killer. Seems to be helping but still...Is there a way to just disable LTE and use hspa/3g?
I created a 2nd APN using my Media Net settings (Name: HSPA, APN Name: wap.Cingular, everything else blank) and the connection will stay off LYE...for most of the time. I just got my Note a few days ago and still doing full charge/discharge cycles, and monitoring battery usage. I've done (4) full cycles and yesterday noticed first improvement. I went 13 hours off the charger and had 68% charge left.
However I don't believe that LTE, as a technology, is to blame for accelerated battery drain, as much as a "weak LTE signal" (or any weak signal). I'm in the Balt/DC corridor, and have noticed that I always have LTE signal everywhere that I've been (and I always check given that I'm a VoIP eng. by trade). I got 40Mbps via Speed Test app in my house, but if I move 20ft into the other room, it drops down to 14Mbps. Not an issue for me, but I do have an issue with the phone reporting 4/5 bars, with a -94dBm signal...especially when -105dBm is the territory where calls start to not connect. Historically I've noticed higher drain rates when signal is lower than -87dBm.
As far as HSPA being "less taxing" than LTE, when switching APN, an locking in HSPA, if nothing else, my HSPA signal is ~ -77dBm, again, in the same spot in my house. FWIW, I believe this is an issue due to marginal antennae/radio/radio configuration with the Note. My T-Mobile branded Motorola Defy, far from a flagship phone, gets a -67dBm HSPA signal on AT&T (again at home), and consistently maintains a 10 to 15dBm advantage over even the International version that my Co-worker has (at our work site).
After my battery has "settled", I'm pretty confident I can get at least 24hrs. out of a charge, with the display drawing most of the power, good enough for my normal use. Now if I can only do something with the oversaturated color...
Good info. I have pretty poor reception at home or at work. At home it shows -99 to -104 most of the time. At home I only get HSPA though, not LTE. The drain seems much slower at home than at work (LTE). I'll have to take a look at my signal strength tomorrow at the office.
This is overnight. The discharge rate while the phone is off is still a bother. I have juicedefender running, CPU down to 192mhz when screen is off. I'm going to see how I can get Att to send me a new battery, I'm sure it has to be that.
No more Battery Issues w/ this new 5400mah power house
[HLI-i717XL] Buy Mugen Power 5400mAh Extended Battery for AT&T Samsung Galaxy Note SGH-i717 with Battery Door
Free Shipping
7% off w/ coupon code:
https://www.facebook.com/MugenPowerBatteries/app_4949752878
