travisr528
Here is a fix I got from ppcgeeks. You need to call sprint and speak with tier 2 tech support and have them enable EVRC-B and set Home Orig to EVRC-B.
This improved voice clarity, and speaker phone quality as well. Volume also seemed to improve. I have not experienced any negative affects due to this change or any additional drain on battery life.
To view:
1) Open the phone dialer
2) Type ##DATA# or (##3282#) (do not need to press anything else)
3) When the screen pops up select view
4) Then select advance
5) Scroll down to you see EVRC-B and Home Orig (this is what need to be changed to improve voice quality).
To enable EVRC-B:
3) When the screen pops up select edit
4) You will be prompted for a password.
5) Sprint will need to give you the password, the password is also your MSL#
6) enter # given and save for later (maybe usefull if you root)
7) Then select advance
8) Tap to enable EVRC-B and then tap Home Orig to set EVRC-B there as well.
9) Press menu and select "Commit Modifications" so that the changes take affect.
10) You can now exit by press back.
Hope this works for you.
BTW I was not having issues before, but I did notice this setting worked better for me. This is the most current speech codec used by CDMA networks.
To view:
To enable EVRC-B:
