Pixel Density is actually a QUITE common problem in this particular forum. The default is/should be set at 240PPI which is what it needs to be to in order to function properly with the Market. Also, this only changes the Pixel Density in the operating system and NOT on the display. For example, if our phone can only display(What Is It.... uhhh) 216PPI but the operating system is set to 240PPI we will still only get 216PPI due to the fact that the display can only display at a max of 216. Now it WILL look different than it does at 240PPI as in smaller BUT it wont be adding any extra resolution. Basically at it will be doing is scaling things down to take less pixels on our display but in fact in the OS it will be taking the same amount as before just bigger pixels that we WONT see on the display. Pretty complicated.
