Root In a boot loop, need help
Well spent most of the day trying to figure this out so I have to ask now. Is there a way to use the dialer codes, ## in CM11 or is there a sense rom I can flash? I'm on Ting and since this phone wasn't working for a while I switched to another phone and need to use the ## code to get this one back on to Ting.
You can't use those codes in CM. You'll need to flash a stock rooted ROM for them to work. The only one I can currently locate doesn't have working links, and I haven't been able to get it to flash properly myself. Maybe it'll work better for you. I'm uploading the copy I have to another server.
Ideally if you're going to be doing any network switching like that, you should do it before flashing any custom ROM (like CM).
EDIT: https://s.basketbuild.com/filedl/de...wel_stock_rooted_Sense5_Android4.3_deodex.zip
If that doesn't flash, I'll have to harass the guy that built that zip to fix it for you.
I know, he said sheepishly. With all the problems I had trying to flash this I completely forgot. I guess worse comes to worse I could lock, flash the RUU then do the ## code then s-off again right? On the bright side at least I know how to do it all now ;)
Also, I flashed TWRP but when I rebooted it uses CWM. I don't care that much but would I just reflash TWRP to get back using that one?
And that rom failed for me too.
When you're S-OFF, you don't have to relock to flash anything, and flashing an RUU will not change your S-OFF status :). One of the benefits of being S-OFF ;).
