Root In a pickle lost ext2 part!!
Hello
I seem to be having a little trouble in understanding how to partition my SD card for Android Apps2SD. I have a rooted HTC Desire and I am keen to try out Cyanogenmod, I deleted the ext partition by mistake and I cant seem to create another one as I used ROM Manager last time, but now I cant get into my phone, only recovery mode.
Please can someone explain which recovery image I should use to partition my SD Card with some instruction.
Thanks very much
Hello
Thanks very much
Try turning your phone off & removing the battery, check your sd card is seated in correctly.
Now replace the battery & turn the phone on, retry partittioning your sd card with rom manager.
If the above doesn't work copy your sd card contents to your pc , Format the sd card then try partitioning before copying your sd card contents back again.
