kingdave
Hi all,
When using my DHD in car as a sat nav I use the standard USB cable that came with the phone and a cigarette lighter USB socket from my local supermarket.
While this allows it to mostly retain a charge the battery does deplete somewhat on long journeys.
Is there a better socket or cable I can use to prevent battery use, or even better, actually charge the battery while still being used as a GPS?
Thanks
Thanks
