Root In love with CM7... couple issues though?
ssddyakno
I'm using what I believe is the latest RC build. Finally stopped missing my incredible and fell in love with the phone.
1) Wifi tether didn't come with it. Is the process to get it running pretty simple? I can't find the program I ran on CM6 with my Incredible. I believe it was simply called "wifi tether"
2) I believe GPS isn't working properly. I know a lot of people are having problems with this. Is there any sort of fix for this right now or do I just have to wait for a final build?
But other than that it seems to be VERY stable.
Any help is appreciated!
Worm, I'm having trouble finding a simple GingerBread Rom with Sense on that Rom list provided at the top of the forum. Is there one that's not a huge download that you know works?
GPS is working. Flashed that ROM, got lock and presto.
But seriously, can somebody explain why that works? I know GPS will get a lock quicker if you're close to your last location when you activate it again, but what's the deal with sense/aosp?
:D I wish I could explain why it works like that. All logic says that if you wipe it should wipe all the GPS stats as well. There must be something that is remembered between flashes that cause it to "know" how to lock on. I don't think anyone knows why it work just that it does.
The GPS fix is kinda wonky...i read about how/why it works but really didn't understand it. but here goes my short and sweet explanation.
AOSP android does not have "network location" capabilities.
Sense, Blur, Touchwiz, ect all have it working with their networks to get you fairly close to your location (for security/safety/weather ect)
when you flash a sense ROM and get a GPS lock, something remembers the "network location" code (i guess) and keeps it in memory, so when you restore your CM7 nandroid, it remembers that "code" and applies it to CM7.
something along those lines....lol
as for the wifi tether. check out open garden wifi tether. looks exactly the same as wifi tether for root users (except has a different icon and different background) and works just as good. i used it this weekend for about 10 minutes with my touchpad.
That line I feel weary about. If that were the case then why would anyone buy a Nexus phone. Also the trusty SDK says otherwise.
Name of the network location provider. This provider determines location based on availability of cell tower and WiFi access points. Results are retrieved by means of a network lookup. Requires either of the permissions android.permission.ACCESS_COARSE_LOCATION or android.permission.ACCESS_FINE_LOCATION.
Constant Value: "network"
Source
I think the fix may help with something along the lines of the following string in the SDK
getLastKnownLocation
Returns a Location indicating the data from the last known location fix obtained from the given provider. This can be done without starting the provider. Note that this location could be out-of-date, for example if the device was turned off and moved to another location.
Source
All of that is in API level 1 which would mean it was in the SDK since before the initial public release of Android (cupcake)
i'm using rc.1.7 and the issues i have are that 1: the gps doesn't work at all. just spend the 4 bucks for root explorer in the market and followed the link to xda in one of the above posts and that didn't help at all. also, my phone doesn't receive calls half of the time.
Are you on the proper radios? That might be the cause of the call missing.
You need to flash a Sense rom and get a GPS lock the restore back to the CM7 backup you have and it should fix the GPS issues.
link to newest radio, please? also, how can i tell what radio i'm currently on?
I just tried to go from RC 1.6 to RC 1.7 and got the dreaded boot loop. Tried 2-3 other things to get it booted up and couldn't, so went back to Nandroid of 1.6 Not sure why I was concerned with 1.7, cause 1.6 worked wonderfully for me.
Radios in 2nd post
check the baseband info compared to this
MR1 1.13.605.7 1.16.00.0402 n/a
MR2 1.66.605.2 1.39.00.0508 0.01.69.0510
MR2.5 1.68.605.3 1.39.00.0528 0.01.69.0602
MR2.75 1.70.605.0 1.39.00.0627 0.01.69.0625
2nd GB Leak 2.07.605.0 1.46.00.0704 0.01.76.0703_2
3rd GB Leak 2.10.605.1 1.48.00.0726 0.01.78.0802
4th GB Leak 2.11.605.0 1.48.00.0817 n/a
I would suggest the 3rd GB leak if you are on lesser radios.
Did you check the MD5 of 1.7 before flashing? Also wipe until you are clean:D If you have a good MD5 and a normal wipe doesn't help I would format /system, in CWM the setting is in the mounts menu, in TWRP the setting is in advanced. Follow that up with a factory reset and wiping cache/dalvik cache
couple of questions. i'm currently downloading the radio you recommended. how do i check the md5 (or whatever it's called) and also, how do i flash the radio?
AFV is what I use to check MD5sums. First copy/paste the MD5sum from the thread in a notepad app (I use color note) then check the MD5 with AFV and paste that into the note to make sure it matches. If it does then rename the zip PG05IMG.zip and place on the root of your SD, power off and when powering back on hold volume down. That takes you to hboot, it will ask you to update press volume up and then reboot when prompted. Now delete or rename the zip file you renamed so it will not cause issues in the future.
sorry, but i still have no idea what you mean about the md5 thing. where do i get the md5sum? i downloaded the afv (america's funniest videos?).
LOL no, android file verifier :D
Open the app, navigate to your download folder and long press on the zip you wish to get the MD5 for. It will pop up a long list of things you can get the top one will be the one you wish to pick "Calc MD-5 Check Sum" or something close to that. Your phone will think for a bit and then pop up the MD5, it will also copy it so you can paste it in the notepad
it's not updating! i changed the name and put it on the root of my sd card and it gives me an error message.
What error are you getting? I would double check the name it should be exactly "PG05IMG.zip" If you renamed with a computer then it may have put an extra .zip on it.
Posting this so the information is public on the forums for search purposes. This is a message between me and Yeahha.
So I flashed the one you told me to flash. I can receive calls, but the network is stuck on 1X. No 3 or 4 g no matter what option I select in wireless/networks. A reboot didn't happen either. Is there time it takes to recognize it? Or another radio you would recommend?
Yeah don't add the .zip
Windows already puts it on there and doesn't show it, so if you type it, it's gonna be .zip.zip and the phone won't see it.
Make sure data is enabled and you don't have use only 2g networks checked also network select should be cdma /evdo + lte auto so something close to that
