In the lock screen settings, the ink effects are greyed out. But if I select the unlock effect "Ripple" the ink effect will be enabled. But no ink effects in the lock screen. Shouldn't it be enabled for the "Watercolour" effect?
Settings/device/Lock screen/Unlock effect/Ripple/then below 'ink effect' should be available, just choose your colourYea but in ripple, there's no ink effect to change colors right?
So basically when you change from watercolour to ripple, then the ink colour becomes available.
Edit: I am using the factory unlocked Note 3 European handset, for reference.
Hehe.. tried that smart trick but didn't work for me![]()
