Root INC not working properly after long time sitting
Sarosh79
I had my inc replaced with HTC Thunderbolt a year ago, but then later gave to a friend. Then she got a iPhone 4S. It had CM7, I think she accepted the OTA update when it came up. So now it will not let me download any app, it says CWM is not installed, I tried to install it through ROM Manager, no success, tried to run unrevoked again, no success.
I checked to see android version, its 2.3.3. So IRCC its supposed to be 2.2 or older correct? It still has S-off
So I went ahead and tried to do the 2.2 downgrade, cant get past the mtd0.img push it says,
d:\HTC Incredible stuff\unrevoked3>adb push mtd0.img /sdcard/
failed to copy 'mtd0.img' to '/sdcard//mtd0.img': Read-only file system
Are the other commands working properly? Copy and paste your adb session and post here ...
ok here it is
d:\HTC Incredible stuff\unrevoked3>adb devices
List of devices attached
HT04CHJ04801 device
d:\HTC Incredible stuff\unrevoked3>adb push flash_image /data/local/
cannot stat 'flash_image': No such file or directory
d:\HTC Incredible stuff\unrevoked3>adb push flash_image.txt /data/local/
1644 KB/s (75805 bytes in 0.045s)
d:\HTC Incredible stuff\unrevoked3>adb push PB31IMG.zip /sdcard/
failed to copy 'PB31IMG.zip' to '/sdcard//PB31IMG.zip': Read-only file system
wait u have s-off right? then all u have to do is use fastboot or flash the PB31IMG.zip in hboot im guessing to flash recovery
thanks next time that happens to me again, I'll do the other method. I won't be using it for much long, will be getting the Galaxy S3 next month.
