Help Incoming call notification keeps changing
stormcrow
Hi Guys,
I have a weird problem with my optimus one. My incoming call notification keeps on changing everytime I recieve a call. Sometimes I have to slide the icon (circular) to the right/left to answer/reject a call. At other times I get these rectangular shaped icons which I only have to touch to answer/reject the call.
I don't know why the phone can't stick to one particular style. Also if there is an option to actually change the incoming call notification style, I'd rather choose one and use it myself rather than have the phone springing up a surprise on me each time I get a call.
Is anyone elese having the same problem with their phones as well?
Do let me know...
There's nothing wrong with the phone.
When it is locked you get the slide to answer buttons (circular)
When phone is unlocked you get the block shapes that you click.
Try it.
Try it.
Indeed! Thanks mate. Do you know if there's any way I could make it stick to the 'block' icons, regardless of whether is locked/unlocked? I much prefer it to sliding my finger across in order to answer a call.
Disable the Phone locking.
