Help Incoming sms replies placed before sent text
djsilver6
I can't understand why this is happening, but if I send a text and the recipient replies within about 1 minute of my sent text, then their reply is placed above my text to them.
This started happening sometime when I was using Android 2.1, and has persisted with Froyo (2.2).
What my device shows:
And what it should look like (corrected with photoshop):
That can happen in some tower proximity, weather, etc situations. It's not a true glitch in your device or the firmware.
It's just that the reply to your sent message is probably hitting a split second of less than optimum transfer rate on their equipment.
I had this problem too. I think it might be an AT&T issue.
If you're rooted, ClockSync is great. Solved my problems. If not, you can still use the program to get the correct atomic time, and manually adjust the time as required.
I also had this problem. Fixed itself as soon as i installed a different text messaging app (both chompSMS and handcent fixed it).
Althought I prefer using the downloaded apps, I uninstalled them out of curiosity and the problem arose again
This happens to me ALL THE TIME on my GS3 on AT&T... I will try some of the suggested apps above to see if it resolves my problem but it didnt start happening till after the major update.
