UnexplainedBacon
Member
Hey all,
I first noticed a problem when trying to launch the Weather app on my 2.1 equipped Droid Eris. Had it for about a week now. The app crashes every time. Things I have tried:
- hard reset of the phone
- remove battery
- reset Sense to defaults
- cleared application data/cache from weather apps
I was going to try this last one again when I noticed something very very weird. When I got to Manage Applications, and click on "Weather" it actually takes me to the application info for Quickoffice! It now seems like all the weather apps (and some others) are messed up. If I click on "HTC Weather Wallpaper" it takes me to application info for Visual Voicemail. " HTC Weather sync provider" gives me app info for Clock Widget. If I click on Clock Widget, I get info for Mabilo Wallpapers (app from store). What the heck is goin on here....
Any suggestions on what to try? I have searched Google and the various forums extensively and cant find any instances of other people having this issue.
Thank you!
** Edit ** Whaddya know? Soon as I posted this, the Weather App now shows the correct application information. BUT I cant click on anything and it shows 0.00kb. It still crashes on loading too. Also, the other apps are still messed up! Completely random associations between the apps on the list and application information.
- remove battery
Thank you!
