Incorrect Scripts
varun.chitre15
Android Expert
After studying the init.d scripts i have come to know that whatever tweaks i have applied in build.prop all are reverted back by those init.d scripts.
for e.g: In my new update of build.prop i had put v m heap size as 64Mb but 99tweaks script reverts it back to 32Mb.
there are many such aspects in those scripts that revert back all the tweaks to their default values set in the scripts.
I am making some changes in those scripts and finalizing them.
i will tell here which scripts to delete and which not to delete and make an alternative replacement.
First i will test them on my mobile and then post them here along with the replacement scripts and the updated build.prop and the directions to use them.
i will need some time as i m going to a function and return back at 8pm.:)
Vm heap size 64mb hey do you want to brick your phone...the highest value I know was 48mb that is why ini.d scripts have 32which is the best value
Yeah 64Mb is quite big but nothing will happen, it will never never never brick a phone.......
V m heap size is memory allocated from RAM memory to v m heap.
It usually makes cache management better.
Setting it to 64mb will do nothing to my phone because android system requires 48mb at the highest and setting it higher is useless i know.
i will turn it to 48mb.
I need help.
i have created a script.
can i name it anything like tweaks or there should be a specific name for it.
another question:
Instead of using lots of scripts can i make a single script of all combined in that.
Everything is ready just waiting for answer.
then i will test it on my device and upload it.
Also the new updated build.prop is ready.
I will wait till 10.00pm for answer otherwise wl upload it tomorrow.
