Help Increase internal storage space, I know its possible ???
Dodge34
I know its possible, but is it easy and foolproof, don't want to risk my phone safety, its already rooted so the first step is done, I have a 2gb microsd card and can safely have a 500mb of it for apps, is there any easy tutorials anywhere to do all the steps with no complex commands to do it.
I used to Link2sd ... can internal storage APPS .
Sorry ! for my poor English . It is Apps "Link2sd" easy to use
And not need any commands ..type in
u can install "app2sd" on ur cell-phone
Yes you can use Darktremor's A2SD but you will need to be rooted and running a custom rom. A2SD allows all apps and their cache and data to be on you SD-EXT, thus freeing phone internal memory (maybe space) allowing phone to perform tasks slightly better and faster
OR
If you have a GT-5660M Model of GIO, then you can try this method
Hit thanks if this helped you!
