Help Incredible picture transfer
yes...you plug your phone into the usb, connect it to the computer, then it shows u the sd card icon n the phone icon...you open both folders, then u copy all the pix in the phone folder then drag them to the card folder...easy as pie, :) lol
should be in the DCIM folder... Also the popup you get when you choose to mount the drives should be transfer pictures, I suspect the wizard would work fine, but I haven't tried it, just transferred manually.
You can also download an app called Astro. It let's you.look.at your files on your phone and.copy, paste, or move back and forth from your phone memory to SD card
Astro File Manager can transfer between the two on the phone, no computer. Internal Flash is labelled emmc and the micro sd is sdcard. pix in DCIM for both.
I tried connecting my phone to my computer with the usb cable, and got this message: "The disk you inserted was not readble by this computer." Any ideas how to fix this? I have a MacBook. Thanks.
