Incredible S largest charge smallest battery?
zijincheng
Hi, I know that the stock battery with the incredible s is 1450mAh, and it lasts about 8 hours moderate usage, but I would like 10 hours heavy usage.
What is a battery with the largest charge but still fits into the original incredible s cover?
I have an 1800mah battery that fits & have seen 1900mah that fit after taking the sticker off.
The 1900mah is the largest that I know of that will fit, just barley, after removing the sticker and using rubbing alcohol to take off the remaining glue under the stock battery door.
If you want I can give links where to buy.
The one I have is called Mugen power 1800 slim extended, the 1900 is called chicitech...
