Did it work? I am having similar problems, but obviously don't want to lose any apps or data.
Yeah, did mine last night with My Backup Pro and had similar issues as you. Not all apps appeared on the home screens, had to set up all my synch accounts from scratch, I lost all on-screen folders I'd set up, not all data for the apps was restored as most apps started as if it was the first time. Also, it was a pain to have to manually "walk" through the install of the restored apps. Not the sort of experience I was expecting from My Backup Pro!Sorry, forgot to report back..
Yes, it worked
Just a word of warning though.. Before you or anyone else for that matter tries the factory reset.. Make sure you have EVERYTHING backed up!! Even after I backed-up and restored everything using My Backup Pro, most of my app icons didn't return to my seven desktop screen (about 100 apps.) Only a few showed up so I had to try and remember where they all went again
Also.. If you have purchased apps on your phone and following the factory reset you're phone tell you that you need to buy them again DON'T!! Just go to the Play Store and get them again from there, as they should show up as already purchased there. Mine did.
