Hitch_Itch
Member
I first called tech support because my 1x signal and my 3g signal was 0-1 bars with my new Incredible. My 3 year old LG flip phone and the 3 other phone on my account (motorola moto's x3) ALL have have 3 bars of signal. When Im talking on the phone (incredible) it will disconnect and a message would come up "signal Fade, call dropped" also I have been on the phone with someone, and right in the middle of a conversation I would here a bunch of digital sounding blips and a message would say"all circuits are busy, please try your call gain later" and then the call would disconnect. I have not experienced either one of these problems with and of the other 4 phones. Tech support said its a bad phone, we will ship you another phone.
They did, I started it up and activated it, On my home screen I saw 3 widgets that does not come stock with the phone, (wifi widget, bluetooth widget, gps widget) at first I thought maybe this phone had a newer software ver in it, not so I compared all software/hardware/build versions from first phone and second phone, there were both identical. So I looked in my programs, widgets, shortcuts and I cannot find those widgets anywhere. with this replacement phone I cannot recieve new gmail unless I open it , hit menu/refresh. another problem with this replacement is i cannot use wifi, It shows Im connected to my wifi but it wont work, (transmit/receive)
I called tech support again, told him what is going on with this replacement phone, they said they will send me another replacement phone.
This will be my 3rd phone.
What good is the phone if it cant do the most basic function, (make a call)
Anyone else having issues like this? If this 3rd phone doesnt solve my issues, they said they will probably let me out of my contract,
thanks for any input
Ken
Ken
