Incredibly Confused (no pun intended)
ok, just got my incredible and i want to sync up the mail client with my school account. My school used microsoft outlook. I guess what im asking is how do i do it? I dont understand where to find all the information that is needed
Thanks!
In Outlook:
Tools > Account Settings > Click whatever account you want > Change
Then copy the settings into the Mail app on the Incredible.
Unless you aren't currently using Outlook, which then you should ask your school.
Search the forums there are a couple threads about it but in a nutshell you need your school's pop or IMAP settings depending on which system it runs on. Check the account info in outlook and copy that maybe
Thanks!
Settings -> Accounts & Sync -> Add Account -> Exchange ActiveSync -> Entered in E-mail Address & Password
I believe that was the only thing I had to do.
