Help Independent widgets for different calendars?
ODog2323
Is there a way to get a pair of calendar widgets (stock or otherwise) to independently display events from different calenders? In other words, I want to have a cal widget on one home screen display events only from my home calendar, and another widget on another home screen display events only from my work calendar on the same gmail acct. Seems having this happen with one gmail account might be the tricky part, as the couple apps I've tinkered with so far only seem to want to pull all or none of the calendars on my Google acct for each widget.
NM just found the setting for this in Android Agenda Widget. If anyone's looking for a nice cal widget that one has loads of customization options. Maybe not so hot in the looks department though. I can't get it to fit with the honeycomb decor :)
