INDICATOR LIGHT APP INSTALLED
When I receive a call, text, email on my old phone
(Samsung Galaxy S7 Edge) I had a blue light flash. My new S21
doesn't seem to have this option. The light would flash, till I cleared it. Any suggestions?
there is no setting unfortunately. your phone was built not to have this feature any more. but, you can try several apps that are out in the play store.
like this one:
LED Me Know: Samsung Galaxy Notification LED
I spent $800+ for my Samsung Galaxy S21. I'm still not satisfied, not having a Notification Indicator Light. Someone suggested I spend additional money for a Samsung watch. I don't wear a watch 24/7. I have tried a couple apps, but the Indicator light goes out after a few minutes. I would like the light to continue blinking, till I clear it. That's how my S7 was.
the problem is that many do not see a need for this.....such as me.....so the samsung has not kept that functionality. if more people were to make a stink about it....but i doubt that will happen.
have you looked at the other led notification apps on the play store?
you can check my search here:
https://play.google.com/store/apps/...hWCARIKEGxlZCBub3RpZmljYXRpb24=:S:ANO1ljK3AEQ
or take a look at this app:
https://play.google.com/store/apps/details?id=com.jamworks.alwaysondisplay
OCNBRZE, thank you for your assistance. I installed "aodnotify" it solved my indicator light issue. Light blinks till I clear it. Also many cool options with this app. Thanks again!
