Help Infuse Phone messing up? Help
Ok i've had my phone maybe 5 days now and today i took it out of my pocket and while in my hand it vibrated once and the phone wouldn't turn on i tryed the power button maybe like 6 times and waited then it finally came on,but it was really slow and kept freezing and pictures not showing up??(picture frame widgets) this has happened before,taking a while to turn on being slow to respond,Is this normal??Maybe like a computer waking up from deep sleep. This is the first day I didn't charge it at night but the battery said it was at 49%. Another problem is after it came on finally, it had no bars just a circle with a line through it and words kept on appearing like scanning media ect ect like it was just turning on...(my wife had full bars) and mine wouldn't get any bars,so i turned it off then back on and the bars came back on????? Is this normal? or is something wrong with my phone because i can still return it because its within 30 days
Been pretty standard with my startups... Blue circle with line through it means ur getting no signal... But thats usually for just a minute or two while the phone does a media scan which are those white symbols that pop up on the top left of ur screen... Try restarting ur phone... If u get that blue symbol for too long then yeah id consider swapping it out...
...or try a different rom i have had no problems with infused v2.2 except gps but you can go to 2.2.2 for gps... Having a different rom fixes everything, and mine boots up really fast with it. Roms overall make your phone better, and if you do not like it then you can always go back.
I like the phone its just sometimes i don't know if this is normal or whats going on,i know when the phone is off and i turn it on it does all that media scanning and all that so i would expect maybe it could be slow starting up and kinda slugging untill everything starts up, but if i just looked at it 4 minutes ago and then try to look at it again and it takes like 2 minutes to respond and come on and then everything is so sluggish and i don't get any signal and have to turn it off and back on to get it to work,but i guess ill maybe wait to see if that happens again or maybe just exchange it for another
Yeah the startup time can be a while especially if ur in a hurry... But i dont think its better or worse than a lot of droids ive seen
Fon freezes some times but my signal is waaaaay better than that, I'm close to the city, att wifi, EVERYWHERE....
