Infuse stuck on Edge
bdp8lax
I have had my infuse since June and had no problems but now I have had issuses with it not connecting to 3g and only showing E when I am in and area that should definately have 3g. I am also sometimes in areas that should have HSDPA+. Any help with this issue would be appreciated. Thanks
I've been stuck in EDGE for the last 5 days. Techincal Support made me go out and get a new SIM which didn't do anything. AT&T Tech Support has not done one thing to help me. It's not the network or throttling, could it be the internal antenna? Looks like there's other people with the problem, have any of you found a fix for this?
Before you ask,
Yes I checked that packet data is enabled
I've triple checked my APN settings
I've tried playing around in the *#*#4636#*#* menu with GSM settings
Combined with a brand new SIM and a supposed "update" tech support uploaded, I can't use any MMS. I'm getting speeds at .18 MBPS down and .23 MBPS up...
SOMEBODY HELP!!!
