Help Infuse Tether
I was rocking the tethering codes on my Inspire.. and it worked great for the hotspot. Has anyone figured out how to make these codes work with the infuse? You can put them into phone, and pull up the hotspot option, but I'm not sure if it will cause me to activate the tether plan on AT&T or if it will use the codes I put in for the APN...
It was easy for me to put tethering code to my inspire too. I am going to do the same when I pick my Infuse in two week. But will return it if doesn't the way like I did to Inspire.
