(HTC Desire running 2.2) Sometimes the init process enters a busy loop, consuming all CPU time. This has happened to me three or four times now. When it happens, Android System Info shows 100% CPU usage and if you run top in a terminal emulator, you can see that it's the init process eating up the CPU. This makes the phone real slow and the only cure I know of is a reboot.
I was going to check out the logs while the init was looping, but I forgot.
I don't know how to repeat this - today it happened when I exitted VLC Stream and Convert, but it happened before I even installed this application.
I think this happened before the 2.2 upgrade as well and my son said his Xperia X10 eats the battery real fast sometimes - so maybe the same problem exists in Android 1.6 already.
Anyone else seen this?
