Seeing as the vigor isn't out yet wouldn't a replacement battery be hard to find not to mention expensive?
Okay I suppose they aren't that hard to find, I guess I could have used google.
^Post edited by mod.
We play no favorites and we have no pets.
Earning a ban on your own merits is easy.
It just as easy being cool and not whining to others when all they wanted was some battery advice.
Your choice. No one else's.
The reason I went with the above battery, even if I decide not to get the HTC Vigor, at least I can use this in the Thunderbolt.
"My name is Doug...and I'm a Thunderbolt-aholic..." (all reply - "Hi Doug")
With that said, I was thrilled to read this post that the Vigor battery with a higher mah will fit and work with the Thunderbolt....now....for the million dollar question...
Have you been able to see an actual increase in usage time between charges with the Vigor battery? If I can get a few established reports that it will be a very noticeable increase in usage time between charges, I'm definitely putting that battery on my list of stocking-stuffers for Christmas!![]()
I have had the Seidio 3500 for a couple of months and absolutely love it!!!! It is the same size as the standard extended battery. I can easily use my phone for anything I want ALL day that includes web browsing, about 100+ texts, calls, pandora radio, gps stays on, bluetooth, etc. I unplugged my phone at 10am this morning and currently have 60% at 3am after everything listed above all day.
I think i've decided to just get a wall charger, and keep the slim look of the thunderbolt..I charge my phone every night anyway, so another slim would be enough to get me through my day, and them I can charge them both overnight.
I switched ROMs a few days ago and noticed much improved battery life. Where I'd have about 20-10% near the end of the day, I now have 50-60% battery life. I'd say it has a lot to do with the apps that I had installed, but also the old Gingerbread ROM that I was using seemed a bit buggy.
What did you switch from/to?
