input through blue tooth keyboard
Hi i have just got a cerulian blue tooth keyboard to use with a Samsung galaxy note2. The devices claim to be paired - code numbers input, device showing as paired on the phone. I can't work out how to actually get it to accept any input from the keyboard. Is there a setting, a piece of software, an app I need to be able to do this?
Thanks
alan
I didn't have any issues using a bluetooth keyboard for an iPad on my Note 2.
Sorry, I can't give you any advice, other than maybe try another keyboard?
Like Granny said, when I paired my Logitech BT Keyboard for the first time, I had to go into settings to the keyboard settings and choose it. After that, no problems at all. When its not attached, the pop-up comes back like normal.
