Fyrefly
Does anyone know how to get rid of the slide down lock and just have the pattern lock?
Just figured this one out
Settings>Security>Set up screen lock
I just set that up and it works fine, however, while it adds the pattern pw, it retains the pull-down unlock. Are we stuck with that or is there a why around it?Just figured this one out
Go to People > All > Press the Menu button > View
Is 'Exchange' listed AND checked under options?
Previously had the Captivate with LauncherPro installed. I see no need for LP since it is basically Sense, but I really miss the dock that LP had. Is there anything similar in Sense or maybe some type of addon? Not the end of the world or anything, just really liked that dock.
HTC Mobile Phone Support - HTC Inspire? 4G - DisplayScenes are pre-set home screen configurations that can be accessed from the home screen by pressing Menu>Scenes. Each scene has its own style/layout. You can use either the preconfigured Scenes or create one of your own.
To create your own custom scenes, select your wallpaper, widgets, shortcuts, etc. Once you have everything configured, to save the style, press Menu>Scenes>ensure that Current (unsaved) is selected and touch Save. At this point you can name your scene and then press Done to save it. Once saved, this Scene will be listed among the preconfigured Scenes for selection.
Please Note that there is not an option to save alert tones (ring, sms, etc) as part of the Scene.
I Have Two Questions.
How Do I Delete The Extra Pages?
How Do I Delete The Apps That Already Came With The Phone?
I read this in another thread, about how the ATT clerk made sure the customer had this magic... thing:
What exactly is that? I think I have one too, which came on a card inside the box, but what do you do with it? That is, I already have a data SIM card in the phone... what's the other one for?
hi everyone! i don't have my quick start guide with me (the one that came with the phone) but does anyone know what that round, led looking dot on the top front of the phone, on the right of the wired stainless steel for the speaker? i know it's not the led light because i see it when you're charging the phone it's located underneath the wire and on the left. is that supposed to be a sensor?
also, i posted this question on another thread but maybe this is a more appropriate one: can anyone tell me the difference between up time and awake time? i tried to search for it but couldn't find anything that actually describes what they mean. people would talk about it as percentage but it's formatted xx:xx:xx. i hope someone can explain it to me.
I want to setup my yahoo mail with the phones email. I already setup my gmail account in it. But I cannot get the yahoo mail to work. I've used these settings I found in another posts.
Incoming
Protocol: IMAP
IMAP Server: imap.mail.yahoo.com
Security: None
Server port: 143
Outgoing
Check Login required
SMTP Server: smtp.mobile.mail.yahoo.com
Server Port: 25
I don't know if you figured out yet but I thought I would throw my 2 cents in. Make sure your wifi is OFF while setting up IMAP or it will not work.
When I unlock my phone, the clock widget seems to always update itself by flipping and it is always exactly 1 hour 2 minutes behind my time when it flips. Does anyone else do this, is that just the way it is or is there a setting I need to check.
Watched some Youtube vids and theirs did it also, have to watch closely when they unlock but their clock widget updates too and it was 1 hour 2 minutes then it flips as soon as they unlock, odd for it to do that but at least it's not just mine LOL!!
wait I think I figured it out, the way I was holding the phone, I was touching the edges. I noticed it doesn't let you touch the screen in 2 places at once, therefore it wasn't allowing me to press the keys. At least I hope that's it.
I'm having the same problem as you. I recorded a pattern through security settings and I'm still getting the drag to unlock screen. Also is anyone else having problems with their voicemail, I'm getting a busy tone everytime I try to call it. Any help would be appreciated.
how do I turn off the vibrate when I type text?
i got the vibrate turned off for the buttons, but I cant find how to turn it off for the text/keyboard
Does sense have a recurring reminder for missed emails, calls, calendar events, etc?
When you snooze a calendar event, when does it pop up again?
Not a question but i cannot believe i could not add Santa Barbara to the weather widget.
