Whenever I try to install a zip rom on my Vibrant I get an error msg. After I ask the rom manager to install from the SD card and select the file from the internal memory it reboots and A very quick installation takes place until it stops on "installing Muti-CSC". After that it just stays like that forever....so I go to "reinstall packages" and the system tells me:
--Install from sdcard--
Finding update package...
Opening update package...
Installing update...
Installation aborted. (in red letters).
Can anyone help?
thanks
Rafa
P.S - I've read the other related threads and didn't find the answer. I've tried with nero V3 and V4.
Can anyone help?
thanks
Rafa
