Root Installation aborted
rawfa
Whenever I try to install a zip rom on my Vibrant I get an error msg. After I ask the rom manager to install from the SD card and select the file from the internal memory it reboots and A very quick installation takes place until it stops on "installing Muti-CSC". After that it just stays like that forever....so I go to "reinstall packages" and the system tells me:
--Install from sdcard--
Finding update package...
Opening update package...
Installing update...
Installation aborted. (in red letters).
Can anyone help?
thanks
Rafa
Your ROM file didn't download properly. If it's Nero v4.1 I had the same problem. Just re-download the .zip file and make sure it fully downloads. Then try again. I had to do this twice, so be 100% sure that the.zip file fully downloads. Hope this helps.
