[solved] stable CM download from their webpage doesn't seem to work for AT&T GS2. see below for details...
trying to install update-cm-7.1.0-GalaxyS2-signed.zip from ClockworkMod Recovery with signature check turned on:
it says something like "can't verify signature of entire file"
turned off signature checking:
assert failed: getprop("ro.product.device") == "galaxys2" || etc
if i try to update from rom manager, and i try "download rom" it also says it can't verify the signature.
wth?
ideas?
thanks
wth?
ideas?
thanks
