Root Installation problem
bombix
Hi,
I have a flytouch with tim's rom.
I was downloading evernote and astro in to my pad and them i made a mistake... i inserted an sd card to copy some files.
Wen i looked the download symbol wasnt there anymore and i could not find neither aplication in the pad.
When i opened the market those aplications wont show anymore. Can anybody help me?
Another thing, when i mount an usb drive, were can i find it?
Thanks in advance,
Fernando
Try uninstalling the apps -> settings/Applications/Manage applications/All and see if they are there to be uninstalled.
USB drives are /mnt/sdcard/udisk1/ & udisk2/
Thanks for your reply,
The aplications arent in the aplications menu.
This sd cards thing its a bit confusing to me. How can you use the internal and the external sd cards?
Any more sugestion about the aplications?
Thanks in advance,
Fernando
Applications - have you tried emptying all the cache areas manually?
settings/Applications/Manage applications/All - look for "Google Services Framework", click on it, press force stop, press clear data,
settings/Applications/Manage applications/All - look for "Market", click on it, press force stop, press clear data,
Reboot. Now try installing the apps again.
SD cards, internal & external & USB disks can be confusing because linux does not use drive letters for device assignments. However, keep trying & learning and you will soon learn how to navigate round the various devices, just remember to always start at:
/mnt
So from the root directory - look for mnt
So now enter /mnt directory
Inside /mnt you will see
/sdcard
So enter /sdcard directory
Inside /sdcard
you will see your storage options:
/sdcard1 (this is the external sd card if you use one)
/sdcard2 (this is the internal sd card if you use an external one - if no external it will be called sdcard1)
/udisk1 (this is usb 1)
/udisk2 (this is usb 2)
hth
Thanks for your ansker,
Ive done as you sugested and still Astro wont apear in market...
I guess flashing is the only solution... any more sugestions?
Thanks for the tutorial on the file system, so you can use both the internal and the external sd cards at the same time?
Thanks in advance,
Fernando
Have you upgraded to the new market app yet? V 3.0.27? I would try that first.
And yes, you can have both internal & external SD cards in your FT3 at the same time.
Dual File Manager & Ghost Commander both have dual pane options so you can have 2 x windows open so you can copy from one sd card to another or from USB to sd card easy.
Hi,
Im sorry but, how do you update the market, i searched the market and no luck...
Thanks in advance,
Fernando
Hi,
i managed to download the new version of market, but still i cant see all the apps in the market. for what i can tell i cant see alot of them.
Maybe this isnt related with the instalation probem.
any ideas?
Well there's lots of reasons why you can't see lots of apps.
FT3 is not a recognised device by google.
FT3 is not licensed to use google android market, as the Chinese Tablets makers will not pay for it to be licensed, so you have to find you own ways to get the apps you need.
FT3 does not have a sim card & IMEI number to allow google market to read your tablet as a device.
All these create problems when trying to find suitable apps for your tablet, and I'm afraid the only way to look for other options, such as alternate markets:
Alternative Android Markets
Using your PC to be creative, like look for the devs own website, or googling the app name + apk and look for the results, or even using sites such as droidappz & mobilsim.
