It usually means that it doesn't like the kernel. If you are using a ulv kernel, try a lv kernel, and if you are using a lv kernel, try a mv kernel and so on. Also, if you have never run at 1.2 ghz, some phones just won't run that fast.
Take the battery out and do a nandroid restore of a known good rom, you do have a nandroid restore to fall back on, right?
Then backup, backup, backup! Have nandroids all over the place!![]()
