Installed Flash Player 11.1 and it doesn't work
Hi guys, sorry if this is a duplicate question, I'm just ultra frustrated with this right now. I have a Samsung Galaxy Nexus GSM smartphone and I just tried installing the latest version of Flash player (11.1) and it says it's installed, and I can pull up the app, but no flash content loads with I visit any websites that support flash. Any ideas? I've tried this 3 times, and the same thing happens every time. Also, if I click the Flash Settings icon, it just loads a blank screen, and nothing happens.
Any help would be greatly appreciated!
Try to uninstall and reinstall, you could do a battery pull while the phone is turned on for ten seconds then reboot. turn wifi on try something like that
Im having the exact same problem.....it worked no problem since i downloaded the apk file a couple months ago....but i went to a news site last night and it said i needed adobe flash player to watch the content??? It is in my app drawer and when i used to press it the settings for the flash player would come up. Now when i press it it asks me to chose which browser i want to use then when i pick it takes me to a blank, black screen..... I used Chrome and the factory Galaxy Nexus browser and neither work.....why is it not working all of a sudden?? Anybody?
The only browser I was able to make flash work on is Firefox. Enable plugins. I am on Sprint gnex.
Unfortunately im with Fido in Canada....it used to work with either Chrome or factory browser before but not anymore.
Im guessing it has to do with an update to google chrome?? Cuz it used to work.....?
Android Chrome has never had Flash support. Android's built-in browser worked with it though.
Really, I wouldn't recommend running Android Flash in any browser though since Adobe is not releasing updates for it anymore. This could create a security risk and not work properly with many sites.
Web developers really need to quit bothering with Flash and other plugin-based systems.
True. However, we are still in the transitional phase. HTML5 support is growing rapidly, which is good. However, some sites still use it for whatever reason (HTML5 features still being tested, legacy/abandoned site). And some sites inherently need it, since their content revolves around Flash animation (eg Newsgrounds).
Personally, I run Flash "on-demand". Then you reduce security issues (only run it on trusted sites) and Flash only runs when I'm actively using it saving CPU time and RAM.
