Root Installed Froyo, now have duplicate items on home screens
Just put the leedroid Froyo with sense onto my Desire and performed the apps and settings restore with Titanium and now a few widgets or icons won't load properly, i have to manually put them back on, which isn't a problem.
Whats weird though is every single item on the home screens are duplicate, so when removing them i have to do it twice.
Also my Youtube widget doesn't load properly while sitting on the home screen, it says to tap it to try again.
Anyhelp would be great :)
Update:you tube refreshes in widget ok now but the upload and search buttons work for a while then stop and you have to reload the widget again.
I have the duplicate issue also. I am using Modacos Rom though...
Strange...
Does't really bother me....
