Root Installing custom rom pls help
Ca5p3r69
Wen i try n install any of my custom roms on my SD it says
Installing....
Finding update package
Opening update package
Verifying update package
E: Signature verification failed
Installation aborted.
What am I doing wrong pls help..... n dis happens wif any of the roms i have downloaded n try to install
What recovery do u have installed? what model do u have? A510c? A510e? You need to make sure u have the right cwm5 recovery. Here is a link.... http://www.mediafire.com/?d58j1nkrrqa5pcm
After u download the file, place it on the root of your sd card and rename it PG76IMG.zip
hard boot the phone and once on the Hboot screen it will automatically scan the file and ask if u want to update. update it and when its all finished u need to take the battery out and the sd card out and delete the PG76IMG.zip file from the sd card or rename it. Then u can hboot, after it scans your sdcard, u can go to your recovery. Hopefully this helps. If not it might be a problem with your root not sticking?
Ok my wildfire s is a510b S-off rooted n I downloaded custom ROMs but im not sure how to install it n yes I'm a noob at these things lol so any help is gratefully appreciated step by step would be grate
U have to use the recovery to install the roms, download the recovery file I showed u and follow my steps. To hboot take the battery out and put it back in. Hold volume down and press the power button.
Ok I got it its salsa 101 Rom slow, market doesnt work coz the sync doesn't work if my Google acc doesn't sync I cannot get my apps back like Rom toolbox n others internet isn't good like b4 I want my stock Rom back would dat fix all d things stuffed up since installing dis Rom ? I regret installing dis Rom wat do I do now ?
U can try a different Rom. Find the one that works best on your phone. I would recommend the cm7 stable build. It should be fast and give u more internal space. Why are u not able to sync? I don't think its a good idea to restore your apps via your Google account, or so I've heard, but I don't backup my apps with google, so I've never had to do that. I just use the market to download all mine.
Yeah but android market doesn't open unless u sign in ur Google account thats the problem n wer do I find cm7 I got a couple of roms from Google at htcwildfiresforum.com
I regret putting dis Rom oh another is wen i go into recovery everything in here is missing the list was so long now its all gone even updates n roms
There is a stable cm7 Rom on the xda forums that should be compatible with your phone
yeah thanks im running cm7 unofficial but bluetooth not working n i cant dial so only can answer calls lol but atleast its fast n im actually happy wif dis do u know any other good roms ???
U will have to check the forums at xda. I have a cdma phone so I only have a couple to choose from, but there should definitely be one for your phone with working bluetooth and dialer. Have u tried a different kernel?
So if I get different kernels it could fix those problems ie. Dialler, blutooth, market
Yes, a change in kernel can fix problems. If you are running cm7, make sure u have the latest gapps and flash it after you flash the rom. The dialer bug can be fixed very easily thanks to UnknownFearNG over at xda.....
You need to have a rooted device in order to do this. Download a file manager such as ES File Explorer. Next, give it superuser permissions by going into Settings of the app and clicking Start on Root and Mount System. Accept the permissions and then go into the /system directory of the device. Next, look for the file called "build.prob" and open it with a text editor to edit it. Look through the file for the line:
# try to disable proximity sensor in call by default
#gsm.proximity.enable=false
Simply delete hashtag infront of gsm and save it and reboot the device.
wer do i find the system directory ?
Deleting the comment symbol in front of that line did NOT fix the dialer issue on my MetroPCS CDMA phone. (A510a)
Not sure if it should fix it or notnot, but dialer is still raping my battery at 99% usage!
