Root installing custom roms for battery life. coredroid? others?
mobile363
Member
sorry im tech literate but smart phones are soooo new to me. in a desperate attempt to improve the battery life of my phone i have been searching. i read that installing coredroid can extend battery life three fold. has anyone done it? worth it? how do i do it exactly? do i have to root? i have a telus phone in canada with 2.2 android. any other suggestions? thanks
Welcome to the forums - you may wanna check this post out http://androidforums.com/desire-hd-all-things-root/354749-how-root-install-custom-rom-desire-hd.html
All explained from there!! :D
As a rule, custom ROMs do offer better battery life, what are you getting at present?
its hard to say for sure. ive had the phone for 4 or 5 days now. i take off charger at 7am and by 5pm i usually have 15-30% left. this is with moderate amount of use. Screen on for at least a few hours during the day, a game here and there, a bit of surfing, texting. Wifi and 3g only on when i need it. no auto syncing. Screen brightness very low. Basically whatever i can do to save battery life.
Its annoying because i dont want to stress about things. If i can do what i want with the phone and still make it through the day, great. But i dont want to limit myself.
Oh, and battery use always says the display is high. Like 60-80% of use. So im not sure if a ROM will lower the use for the screen. Not sure how or if that would work. But that seems to be the issue.
If you've only had it for 4-5 days, it should get better. Generally speaking, the battery is rubbish for the first 10-14 days anyway, it takes a while to bed in. From what you've said, you do seem to be doing all the right things in an attempt to increase your battery life. From what you've said, that could potentially be classed as heavy. Web browsing and Gaming are battery hogs.
Is this your first smart phone or have you used an Android handset before?
I'm not saying don't install a custom ROM btw, I just think it would be better to try and get more life out of your current setup rather than voiding the warranty of a phone that is less than a week old.
This is my first smart phone yes.
I just compare it with a coworkers iphone4 and he seems to get really good life out of his battery. and yea, i want to install a rom as a last resort. I dont want to have a useless $500 phone. I like ideas like reseting and doing a proper deep cycle charge. but even stuff like this it seems can only be done if rooted.
And the HTC rep i talked to was not helpful at all. Just told me to turn brightness down. and all that. I want to give the phone a chance because it really is awesome. Other than the battery.
Leave it a week or so, I was lucky to be getting 8 hours out of average use for the first 10 or so days of having the phone. Now, on the same usage, I can get circa 2 days.
When the phone is at about 10-15%, check the battery stats, what else does it say is using the battery?
You're not comparing like for like though... each smart phone is slightly different - almost like comparing a donkey with a horse... similar, but not the same!
You can reset your phone without rooting - do you mean reset the battery stats? I think there you'd be right... think you can only do this with root access. Should only really need to do this if you flash a different ROM though.
I have seen on here somewhere an explination of "plug in until fully charged, unplug for 1 hour, plug in for 10 mins..." can't remember the exact wording... it "conditions" the battery (not actually the battery, but this tells the phone when it has a fully charged battery) - will have a look and post a link to it (although El P will probably get in there before me!)
That does sound a little rubbish - think he probably meant to set it yourself, rather than leave it on auto!
You'll get there in the end... loving even the battery! :)
I guess you've already seen this thread - http://androidforums.com/desire-hd-...sire-hd-battery-life-comprehensive-guide.html
in fact - the battery "conditioning" I was taling about in my last post is in that thread...
Personally, for the first week I'd let it run flat before charging. Even then, wait a few minutes, turn the phone back on and let it run flat again. I know Li-Ion supposedly do not have a memory, but they need to 'learn' how to charge fully.
Here's a quick guide that works wonders for the folks at TechTime:
Old HTC Desire Trick for HTC DHD, To also help with Battery Life you can do these steps exactly: 1) Turn your device ON and Charge the device for 8 hours or more 2) Unplug the device and Turn the phone OFF and charge for 1 hour 3) Unplug the device Turn ON wait 2 minutes and Turn OFF and charge for another hour Your battery life should almost double, we have tested this on our devices and other agents have seen a major difference as well.
For the first few days my DHD was running flat very fast. I let it run flat, turned it back on and let it run flat again before charging. I did this for the first week to 10 days. Now my DHD lasts 2-3 days on normal use and 12+ hours on heavy use (PocketLegends, browsing, constant Wi-Fi connection (I pretty much am playing with the phone all the time, I have no life).
If I can find the guide that explains how Li-Ion actually DO have a memory (or at least need to be taught how to charge fully) I'll post it (or a link) here.
Cheers,
Sombre.
Hope that is of some help!
