Root Installing CWM Help!
TalonD
I used to have the optimus v ( rooted ) but decided to get the triumph.. I accidently factory reseted on my phone not on recovery so my phone was messed up till I fixed it by installing xionia recovery. After buying my triumph i switched the sd cards and rooted my triumph, but when ever I try to go into recovery mode the letters are blue and it wont let me install or mount the sd card, so I cant install TickerGuy's CM7 mod! Can someone please tell me how to uninstall the xionia recovery and reinstall the regular CWM!
Whatever you had on your sdcard previously should not affect you getting into CWM on the Triumph.
2 questions:
1. Did you actually install CWM on your MT using the steps in the various guides on this site? Here's one of them if you haven't:
http://androidforums.com/triumph-all-things-root/421674-clockworkmod-recovery-motorola-triumph.html
2. IF you did install CWM already, then it sounds like you missed the part in the guides that state:
The controls for CWM 5.0.2.6 (as well as all previous Isaacj87 versions) in the MT are:
Volume up --> up
Volume down --> down
Power --> turns screen black
Menu --> select
Home --> nothing
Back --> back
Search --> nothing
If neither of these conditions are correct, let us know what you've done already so we can give a little better direction.
I did everything on installing the CWM but when I try to go into recovery (Power+Volume up and down) It doesnt stop vibrating...
Glad to hear that you're all set. :)
You might want to edit the title of this post and add [SOLVED] to clarify that you're all set for now.
